Battlefield 1
Publisher: Electronic Arts
We use the DirectX 12 API and the games 'Ultra' preset. We benchmark a section of the single-player campaign as this is the most repeatable and reliable means, though we've chosen a part that we found to be representative of the more demanding areas. Specifically, it's a manual, 30-second run through the start of the mission 'The Runner'.
Gigabyte GeForce GTX 1060 WindForce OC 3GB
Sapphire Radeon RX 470 Nitro OC 4GB
MSI GeForce GTX 1050 Ti Gaming X 4GB
Overclockers UK ForceBox Gamer (GTX 1050 Ti)
Gigabyte GeForce GTX 950 OC 2GB
Gigabyte Radeon RX 460 WindForce 2X OC 2GB
20
30
40
50
60
70
80
Frames Per Second
Frames Per Second
Fallout 4
Publisher: Bethesda Softworks
Our Fallout 4 benchmark is a 30-second FRAPS recording of a manual playthrough, where our character runs forward through a woodland area just outside the Corvega Automation Plant. The scene is very challenging relative to the rest of the game, with massive draw distances and complex volumetric lighting. This means the results below are not representative of typical gameplay, but rather of the most challenging points in the game. We test at the game's 'Ultra' preset, the highest available, and v-sync is disabled in the game's .ini file.
Frames Per Second
Frames Per Second
3DMark
Publisher: Futuremark
3DMark is arguably the most popular synthetic benchmark around today. The DirectX 11 portion, Fire Strike, comes in three flavours: Fire Strike, Fire Strike Extreme and Fire Strike Ultra, which run at 1080p, 1440p and 4K respectively. All cards are tested in Fire Strike using the default settings, as anyone can download and run this exact benchmark for free so you can easily compare your own system's score with those you see below. More powerful cards are tested in Fire Strike Extreme and Fire Strike Ultra as appropriate, but you'll need to pay to unlock these benchmarks yourself.
3DMark also recently added Time Spy, a DirectX 12 benchmark that runs at 1440p. It is designed to properly utilise the advantages of the DirectX 12 API. The benchmark is available for free but you'll need to pay to change any of the settings, including the resolution. Nonetheless, it still serves as a useful at-a-glance comparison of performance in this increasingly important API.
Score
2000
3000
4000
5000
6000
Score
Score
VRMark
VRMark is another synthetic GPU benchmark from Futuremark, this time specifically designed to assess a system's ability to handle VR gaming, although no VR headset is required. The Orange Room test assesses whether a system is capable of meeting the current minimum requirements for an Oculus Rift or HTC Vive VR headset, while the Blue Room test looks towards future VR content with its more demanding 5K rendering resolution and high levels of detail. We run both tests with their default settings so users can easily compare scores here to the free version of this benchmark where settings cannot be changed.
EVGA GeForce GTX 1080 FTW
Oculus Rift Minimum
Score
